General discussion
MK2 GOLF DRIVER ENGINE TEMP LIGHT FLASHING
Topic: MK2 GOLF DRIVER ENGINE TEMP LIGHT FLASHING (Read 3589 times)
tobylee307
Just got here
Mk2 Golf Driver (1.8 GTI engine)
17 March 2017, 18:41 »
Hello I have just got a Mk2 golf driver with a GTI 1.8 8v engine swap. All is good but the engine temp light is flashing but not solid. However the engine temp doesn't seem to show overheating. I know this can't be the case as the light flashes as soon as the car is started and even when it's only running on Auxiliary power.
Share your thoughts!
lemski
Forum addict
16v
Re: MK2 GOLF DRIVER ENGINE TEMP LIGHT FLASHING
17 March 2017, 22:14 »
Temp level sensor that should be in the expansion tank.
Is it ce1 or ce2 fusebox.
I ask because ce1 has a relay for the water temp or level light on dash amd ce2 is built into the clocks.
Something to go on
General discussion
