Author Topic: Lots of fan questions - help needed....  (Read 1977 times)
Offline SafferYork
« on: 13 March 2017, 11:00 »
Hi all.
My fans have not worked since I owned the car - 6 months.
I've done a number of tests - powered up the fans directly (they run) jumpered pin 1 to pin 2 on the temperature sender (runs at low speed) jumpered pin 2 to pin 3 with ignition on - does NOT run at high speed.
The fans are not running at all, ac on, ac off (note here - the ac doesn't work either - clutch isn't engaging).
Could this be the fan control module that is needing replacement?
Any help would be greatly appreciated. And, yes, the fuses have been checked - 40amp, 30 amp in the engine bay and fuse 16 in the cabin.
Mk4 Gti 2.0 2002
Offline bgbazz
  • If it aint broke...I can fix it!
Re: Lots of fan questions - help needed....
« Reply #1 on: 13 March 2017, 16:36 »
 The a/c is unlikely to work if it is out of gas...all the systems I've used wouldn't, but a re gas fixed that.
Can't help with the fan situation...sorry.
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
