Author Topic: Another question.. sorry :)  (Read 2492 times)
Offline Jordan_gti
« on: 27 February 2017, 17:55 »
I am looking to replace all my vac lines with black silicon, is 4mm forge stuff ok? & how many meters to replace all lines?
2002 Golf Gti 1.8T (AUM) LC9Z
Offline lemski
  • 16v
Re: Another question.. sorry :)
« Reply #1 on: 27 February 2017, 20:02 »
You can vet full vac kits of ebay in set colours.
To replace the vac lines and delete alot of stuff a metre and half will do plenty. Youll need bigger stuff for n75 valve though. Although actuator will take 4mm still so youll need a reducer piece
Thing the other stuff is 7 or 8 mm
Offline LR5V
« Reply #2 on: 27 February 2017, 21:34 »
Expensive taste going for forge.
A cheaper option, with more stuff, cable ties joiners and a sticker:
Go to ebay, search "1.8t silicone kit" look for Mr.Silcone kits
Offline lemski
  • 16v
« Reply #3 on: 27 February 2017, 21:43 »
Or boostjunkies as they do a kit.
Offline Jordan_gti
« Reply #4 on: 28 February 2017, 11:10 »
Thanks everyone, will have a look now, it's mainly to eliminate any leaky pipes around the inlet (I've heard that's common) & do whatever else with what's left
Offline lemski
  • 16v
« Reply #5 on: 28 February 2017, 11:35 »
Under inlet to fpr
Dv to other under inlet
N75 to turbo outlet pipe and to actuator
Sai and crank case breather can be simplified and jobs a goodun
