Author Topic: Crankshaft sensor query  (Read 2439 times)
Offline Jordan_gti
« on: 25 February 2017, 21:41 »
Hi, ive recently discovered my power/ Missfire issue was due to N75 & crank sensor, I tried changing this and managed to break the plug on the loom. I need to cut a section of a loom from another golf, however is the loom the same for the crank sensor across all turbo golf's  (AGU engines & AUM ENGINES etc??) Thanks in advance
2002 Golf Gti 1.8T (AUM) LC9Z
Offline lemski
  • 16v
Re: Crankshaft sensor query
« Reply #1 on: 26 February 2017, 08:02 »
It is as far as i know.
Ive swapped crank senosors between the different engine codes
Offline Jordan_gti
« Reply #2 on: 26 February 2017, 21:24 »
does that include the loom itself? as i need about 6 inches of the loom that the plug goes into
Offline lemski
  • 16v
« Reply #3 on: 27 February 2017, 09:04 »
Yeh. Colours should be the same. Ive never really looked closely at the colours in the loom but its easy to find pin outs to make sure
