Author Topic: Starter Enable from selector level sensor system 10763  (Read 9901 times)
Offline Moranatang
« on: 22 February 2017, 22:34 »
Having a few issues with my GTD Dsg 66 plate anyone else had this error Starter Enable from selector level sensor system 10763
MK7 GTD 5 Door Dsg, Santiago's, Tints, Sports sound, Gtechniq Crystal Serum Black
Offline fredgroves
Re: Starter Enable from selector level sensor system 10763
« Reply #1 on: 23 February 2017, 01:14 »
That's not over cranking at start? Fails to fire and when it does you get "auto start stop error"?
Offline Moranatang
« Reply #2 on: 23 February 2017, 06:42 »
Yes every now and then it's cranks over and over and struggles to fire when it does chuck a load of whites moke out.
Don't think I have had an error it's always managed to fire.
Offline Talk-torque
« Reply #3 on: 23 February 2017, 06:59 »
My GTD never went anywhere close to not starting first time. I'd get your dealer to check it out. Might be a dodgy component somewhere.
Roger.
Offline Moranatang
« Reply #4 on: 23 February 2017, 07:07 »
It's in today with them only 5 months old got about 3700 miles on it always ran on shell/bp fuels.
Given the print out as I know there's faults so they can fob me off.
Offline scanesare
  • GTI Clubsport
« Reply #5 on: 23 February 2017, 08:49 »
If this code showed up when you scanned with VCDS/OBD11 it probably is the fact you scanned with the engine running and it's a false alarm. It's been documented that it shows up if you do a live scan. If you clear it, turn off and re-scan it should not pop-up (unless you have a real issue). I was panicking the first week when I did a scan on my brand new CS "just to check" and this showed up together with a bunch of others DSG "faults" only because I did a live scan and not one with the engine off. Hope it's the same for you.
Offline Moranatang
« Reply #6 on: 23 February 2017, 09:35 »
This was scanned when the engine was off
Offline fredgroves
« Reply #7 on: 23 February 2017, 12:16 »
The over cranking thing is quite common - I suspect its this.
I believe there is a fix, but I've not had it done on mine despite it being in the shop only the other day.
My GTD has done this from almost day 1 and after 3 years, it still does it a couple of times a week.
Not really a problem, other than being a bit embarrassing in the factory car park!
Offline Moranatang
« Reply #8 on: 23 February 2017, 14:23 »
My dealer is saying no fix for the cranking over apparently there is a software update other people have said I'll find which dealer they have sent to and get it sorted !
I don't think they can be arsed to sort it
Offline fredgroves
« Reply #9 on: 23 February 2017, 15:14 »
A lot of the fixes for things don't seem to get applied by every dealer. Unless its either a recall notice fault or one where the owner is experiencing a directly resulting problem, they don't bother.
Seems a bit weird coming from where I am at work!
I suppose VW won't pay them to do non-problem causing updates... but when its software you'd think they'd just flash everything in a system wide update.
