Golf mk4
Wazzzer
Left hand side indicator stuck on
Topic: Left hand side indicator stuck on (Read 2239 times)
Morgan3325
Just got here
20 February 2017, 17:51 »
Passenger side indicator (signal light) staying on when engine is on or off jave checked all fises and relays and still nothing
falconmick
GTI forum regular
Golf MK7 R
Re: Left hand side indicator stuck on
20 February 2017, 18:12 »
Have you tried
1 remove then replace bulb?
2 disconnect then reconnect battery?
Morgan3325
Just got here
20 February 2017, 18:15 »
Yes replaced all 3 bulbs on passenger side and dist the battery but still no luck
Nino
Insta - F6UGA
22 February 2017, 22:24 »
Has the steering wheel been removed recently?
VW Car history
- Mk3 1.8 GL - Silver - 5 door, Mk4 1.8t - Silver - 3 door, Mk4 R32 - Black - 5 door, Mk5 GTi - Black - 5 door, Mk4 R32 - Deep Pearl Blue - 3 door, MK6 2.0 TDI - Graphite Blue - 5 door, MK7 GTD - Solid Black - 5 door.
Current
- MK6 GTi Edition 35 - Candy White - 3 door.
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
23 February 2017, 12:21 »
I posted a wiring diagram here recently, think it has indicator wiring in it too.
It was thread on Gora headlight conversion.
Sounds like stalk or wiring loom fault. Maybe missing ground as well. But less likely as it's also with ihn off.
Morgan3325
Just got here
25 February 2017, 17:28 »
Nope steering wheel aint been touched
Golf mk4
Wazzzer
