Author Topic: Easy fixes, One door stays locked  (Read 1677 times)
Offline james2
  • No scammers please.
« on: 19 February 2017, 14:09 »
If you find one of the door locks stays locked and looks like its not working. Do this.
Sit in the drivers seat and theres a switch on the door to lock and unlock the car.
You may need help from someone if you can not reach the lock thats not working.
 On the door thats locked pull the door release handle and lift the lock up hold it there as it trys to pull itself back down, let go of the door handle but keep the lock held up.
 Now press the button on the drivers door and watch all the locks lock and unlock , you need to let go of the lock thats not working the same time as all the other locks go down. When done right it will work like all the other locks..
Tested on my golf and my mums car.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
