Author Topic: Removal of LED rears and Bluetooth  (Read 6550 times)
Offline Buck
  • Das Auto
« on: 19 February 2017, 11:06 »
Hi
Looks like my GTD is going to be replaced soon  :cry: as we need bigger car and if I Part Ex I will swap out the rear 'R' LEDs and Bluetooth module to offset the lower £££ I get !!
I had to code the lights when fitted as there was an error.  Will I have to recode when I remove them or will it show OK?
Likewise, anything I will need to do re the bluetooth once I remove?
I'll have to search out a VCDS as I don't have one if I need to make changes.
Offline dubber36
Re: Removal of LED rears and Bluetooth
« Reply #1 on: 20 February 2017, 11:43 »
It would be easier for the dealer to reset original coding for the lights once you have re-fitted the original ones. At worst you'll have bulb out warnings.
Bluetooth can just be unplugged.
Offline Buck
  • Das Auto
« Reply #2 on: 20 February 2017, 14:00 »
Thanks Dubber
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3 on: 20 February 2017, 20:45 »
If you search on the internet I think ive read Ross Tech posted the info in the past.
Im not sure what the standard code was as earlier cars had it hidden under a 00 displayed code.
Current Garage:
35+ years of GTI ownership.
Offline Buck
  • Das Auto
« Reply #4 on: 20 February 2017, 23:56 »
Cheers Snoopy
Research across a few VW forums/sites tells me I have to change Byte 18 back to '00'
Will have to see if I can borrow a VCDS cable to do this.
Offline dubber36
« Reply #5 on: 04 May 2017, 13:07 »
Did you manage to sort this? I've just sold my GT privately and am taking the .:R rear lights off.
Offline Buck
  • Das Auto
« Reply #6 on: 07 May 2017, 19:35 »
Hi. Yes, all sorted.  I got a local guy with VCDS to recode to remove errors from when the original lights went back on.  Bluetooth was just a case of unplugging - no errors.
I've still got the items I took off to sell - just been so busy but hopefully will get time this week.
What car are you getting?
Buck
Offline dubber36
« Reply #7 on: 07 May 2017, 22:01 »
I bought an Amarok to replace my Passat just over a week ago and a G7 Match to replace my wifes Golf yesterday.
Offline Buck
  • Das Auto
« Reply #8 on: 09 May 2017, 00:58 »
Nice!  Enjoy those  :cool:
