Author Topic: Golf mk6 Bluetooth and rear leds  (Read 2610 times)
Offline K15tue
« on: 18 February 2017, 08:09 »
Hi I have fitted my blue tooth out of my 2010 golf mk6 into my 2009 gt tdi every thing works fine but no 1 can here me ? When plugged into vag com I get open circuit? Can any 1 help also I have fitted gtd led rear light dose any 1 know what setting on vag come I need to select to remove the error codes off the dash thanks
Offline Snoopy
  • Moderator
  • Geoff.
Re: Golf mk6 Bluetooth and rear leds
« Reply #1 on: 18 February 2017, 19:06 »
If the coding is correct sounds like the mic is open circuit. So its either a bad connection, not connected, broken wire, broken mic ir plugged into the wrong socket.
As fot LED tail lights
https://youtu.be/9RPHg3cZGug
Fast forward to 7:28 and he shows you how to manually change byte 18.
For uk cars 15 is the setting for byte 18 and is the setting recomended by staff at VCDS.
Some very very early 2009 cars iirc don't have the software version to allow bypass the warning, fingers crossed yours isn't one of them.
« Last Edit: 18 February 2017, 19:34 by Snoopy »
Current Garage:
35+ years of GTI ownership.
