Author Topic: My new Mk4 1.8T GTI  (Read 1905 times)
Offline Andya36
My new Mk4 1.8T GTI
« on: 17 February 2017, 22:38 »
Hi ya all, got my not so new golf, what I would like to know is they any sensors I should clean or replace, wiring or pipes I should be checking or replacing any advice welcome, she's no spring chicken and I believe prevention is better than cure. Any tips or Advice welcome. Cheers Andy
Offline lemski
  • 16v
Re: My new Mk4 1.8T GTI
« Reply #1 on: 17 February 2017, 23:10 »
Vac lines like to split. Make no end of problems.
Id start there. Simplify the breather sysgem while your there. Id also change the recurculation valve and turbo intake pipe to silicone item.
Theres plenty of threads to go off. When replacing the vac lines you can get it 2 3 and delete the n349 valve while your there.
Basically under inlet to fuel regulator
Other under inlet to dv
N75 lines stay the same routing
