Golf mk4
Wazzzer
Missfire/stuttering
Topic: Missfire/stuttering (Read 2393 times)
Jordan_gti
Missfire/stuttering
15 February 2017, 17:59 »
Just bought a 2002 (52) plate Golf Gti 1.8t (aum) engine. It has what seems like a Missfire, but I have changed the spark plugs, and ignition coils, and it hadn't worked, it feels like the turbo boosts and stops then boosts again
2002 Golf Gti 1.8T (AUM) LC9Z
lemski
Forum addict
16v
Re: Missfire/stuttering
15 February 2017, 18:57 »
N75 valve. Vac leak.
Ive had them where they feel like a misfire but its because the n75 is messing up
Jordan_gti
15 February 2017, 19:12 »
Ive just scanned it with my dads memoscan, its throwing up P0321 , P0172 & a throttle position sensor, do any of these go along with the n75?
lemski
Forum addict
16v
15 February 2017, 19:30 »
1St code is engine speed signal from a quick look on rosswiki -which is crank sensor... Which could be the problem when its trying to get up in the revs
Seconds is the lambda after the cat.
Jordan_gti
15 February 2017, 19:40 »
where is the crank sensor located? gunna try to clean it up
lemski
Forum addict
16v
15 February 2017, 20:58 »
Front of the engine in the block to the left of the oil filter if i remeber correctly. Held in by 1 16sided bolt which is 10mm. Theyre abit arkward to get out some times
Golf mk4
Wazzzer
Missfire/stuttering
