Author Topic: HOW TO: Make your own electric window wiring loom  (Read 11574 times)
Offline Mr Blue
« on: 02 October 2005, 14:50 »
Electric window wiring loom. Can use this diagram for mk1's mk2's and 3 dubs
This will not light up the switches but it does work.
It shows a birds eye view of the back of a switch block. You can use the numbers for other volkswagens
http://img.photobucket.com/albums/v104/sat1s1ngh/switchpeg.jpg
I will try and make a diagram with a relay
Blue :smiley:
« Last Edit: 02 October 2005, 14:53 by Blue Mk2 »
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
Re: HOW TO: Make your own electric window wiring loom
« Reply #1 on: 02 October 2005, 14:53 »
Yep I can confirm this does work as I've got the same format for when I created my loom for my electric windows.
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline GTI EDITION (aka LTD)
« Reply #2 on: 02 October 2005, 15:23 »
Your diagram is good but I would just like to add that I have fitted after market electric windows to various mk2s and mk3s in the past and have found that some aftermarket switches do not have the same terminal pattern as your diagram (which looks like the O.E switches ), ie the terminals are lined up in parallel ( one below the other ) .
They were the dealer fit kits but I think they were made by an Italian firm (and the insructions were not translated very well .:rolleyes:)
Hope this info helps as some might get confused if they have got the switches that I have described . :undecided:
Oli :smiley:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline ...joe
« Reply #3 on: 21 May 2006, 17:18 »
why won't this light up the switches? is it possible to splice into the blue/grey wire which does the lights? or any other way to get the lights to work?
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
