Author Topic: How to stop headlights from fogging up  (Read 6688 times)
Offline Wrex22
« on: 06 February 2017, 18:06 »
Today it rained heavy all day when I got home I noticed that both headlights were completely fogged up. This can't be normal , plus I thought xenon lights had to be kept clear to prevent other road users from being dazzled
Offline Finglonga
Re: How to stop headlights from fogging up
« Reply #1 on: 06 February 2017, 18:17 »
Perfectly normal and will clear on it's own. Every car I have had with HID's has done exactly the same. Only time to worry is when there is water droplets running and pooling and they do not go away.
Offline Booth11
« Reply #2 on: 06 February 2017, 18:22 »
Very common issue.  Headlights are not sealed unit so air can get in, and similarly get out.  Some people pop silica gel packs in to speed things up.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline falconmick
  • Golf MK7 R
« Reply #3 on: 06 February 2017, 18:25 »
As already said, common problem, R forum has many posts relating to this.
Offline Wrex22
« Reply #4 on: 09 February 2017, 22:06 »
Has anyone had any success putting silica gel sachets in their headlight units to prevent condensation ?
Offline monkeyhanger
« Reply #5 on: 09 February 2017, 22:19 »
That will not work - the dessicant will be saturated in no time and you'll be back to stage one again. The fogging clears as the warmth from the Xenon bulbs cause the moisture to evaporate. The warmth given off from the bulbs in use is why these units can't be sealed - warm air expands, and if it can't expand, air pressure builds up inside them, which is going to result in something popping to relieve the pressure (the lens casing or a seal).
Offline GTI_Ant
« Reply #6 on: 09 February 2017, 22:22 »
As Rebecca says these are not sealed units so silica gel bags will saturate quickly, won't the bags be visible and look ugly?  These desiccants absorb moisture slowly so I don't think they will help day to day.  I find the fogging up disappears fairly quickly when it stops raining.  If the sun comes out park facing the sun and the lamps will clear in no time.
GTi Clubsport DCC winter pack rear camera
Previous:
7.5R 3dr DSG DPB Prets Dynaudio
MK7 GTI PP Tungsten Silver Manual Nav Dynaudio Winter Pack Park Assist
Offline itavaltalainen
« Reply #7 on: 11 February 2017, 22:44 »
I just have mine on all the time, no digging up then.
Silica gel helps but you need to take the bags out when saturated and heat them to dry again.
Far too much work for my taste.
Offline Restlessnative
« Reply #8 on: 11 February 2017, 22:56 »
Never had this problem (yet) with my GTD.Had it all the time with my Ibiza.Dealer recommended driving round with my headlights on all the time..... :embarrassed:
Current: Golf GTD MK7  3 door manual carbon grey.
