Author Topic: Help wanted with misfire and power loss  (Read 5358 times)
Offline rob2228
« on: 05 February 2017, 13:01 »
I changed the battery on my car roughly 3-4 months ago.
About a month after that  I was waiting to pick a friend up and whilst my car was running idle the engine management light appeared and the car began to run really lumpy. On the short drive home it felt like it was misfiring and got really jumpy when i put any real power in the throttle.
This problem came and went completely irregularly. Sometimes it would run absolutely fine and other times the EML would pop up and I thought the engine was going to completely give up on me! Every time the problem occurred the engine light would come on and the same issues would occur, it would run lumpy and began to kangaroo whenever I put any real power in it.
I took it home from university (a five hour drive) and it drove absolutely fine. I did some other work on the car such as cleaning out the starter motor because it was making that noise that is common with MkIVs on start up.
To tackle the problem with the engine light/misfiring I changed the water temperature sensor for an aftermarket one thinking that that would solve the issue. This did work for a period of about a month, but then the problem came back. Because changing the sensor had seemed to work before i presumed that, because it was aftermarket part, maybe it had just broken, so i got a genuine VW temp sensor and put that in, but it hasn't solved the issue.
Obviously the temp sensor isn't the issue, leaving me without a clue of where to go next.
I'm beginning to wander, as some people on other threads have suggested, that it's got something to do with having a new battery put in.
MKIV Golf 2.0 GTI 8V AZJ 115
Any ideas on resolving the issue would be greatly appreciated!
Offline lemski
  • 16v
Re: Help wanted with misfire and power loss
« Reply #1 on: 05 February 2017, 19:41 »
Coilpack. Injector. Split vaccummm pipe. Fuel pressure revulator.
When the lights on has it been scanned. Becuase thatll tell you somewhere to start looking other than shooting in the dark
Offline gazareth
« Reply #2 on: 25 March 2017, 18:50 »
I wouldn't think a battery change would give you bother a month after it was done :huh:
Offline Jordan_gti
« Reply #3 on: 23 May 2017, 10:59 »
I've has similar issues myself, im gunna write a list (easiest way lol) & check these items as this is what caused mine;
. Check Crank sensor plug, mine was loose/not fitting and it let it water causing a really lumpy drive with no power. I cleaned this out & re-sealed and it works perfectly.
. Disconnect MAF sensor plug & run without it on, see if it still drives the same, if it drives better , there's your issue.
. Scan the car, even with a cheapy reader as It will tell you roughly what you need to know.
. Check HIGH AND LOW for vacuum leaks, these wreak havoc when they are on cars & its surprising how many issues they can cause with all the knock on effects.
. Check spark plugs & individual coil packs, dodgy plugs can cause misfires as well as packs.
2002 Golf Gti 1.8T (AUM) LC9Z
