Author Topic: Rear brake caliper piston not winding back..  (Read 3625 times)
Offline hardmonkeys
  • Moderator
« on: 04 February 2017, 17:34 »
Piston moves with wind back tool, but isn't actually rewinding back...it was out quite far, and has moved very slightly..any ideas?
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'0 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline lemski
  • 16v
Re: Rear brake caliper piston not winding back..
« Reply #1 on: 04 February 2017, 18:52 »
Take calliper off. Put in a vice. Get somone to turn piston while you put some pressure of the piston. Itll the grab and go back.
Or do this on the car. Possible but sometime alittle tricky
Offline hardmonkeys
  • Moderator
« Reply #2 on: 04 February 2017, 20:05 »
Done now, elbow grease a plenty, all done while on the car..WITHOUT breaking anything...like last time on my mk4 lol
http://www.golfgtiforum.co.uk/index.php?topic=251819.msg2309720#msg2309720
Then it started to rain :-(  carried on for a while, but it started getting heavier and darker, as I was using an extension lead and home made work lamp, I figured it might be best to pack away, I managed to get the pads in and caliper back on, just not torqued up
« Last Edit: 04 February 2017, 20:18 by hardmonkeys »
Offline gasketface
« Reply #3 on: 11 February 2017, 19:44 »
If you get this problem again you can try this,it works most of the time.Take the handbrake cable off of the caliper and get someone to pull back and forth on the arm quite quickly while you turn your,erm,tool  :laugh:
Offline hardmonkeys
  • Moderator
« Reply #4 on: 11 February 2017, 19:54 »
 :laugh: :lipsrsealed:
Pmsl...thanks. Will try it next time.
