Author Topic: Creaky drivers door when opening  (Read 2349 times)
Offline Wrex22
« on: 28 January 2017, 23:19 »
My drivers door is making an awful creaking metal on metal clunk when I open and close it . Anyone else had a similar issue. Appears to be coming from the hinges area
Offline Restlessnative
Re: Creaky drivers door when opening
« Reply #1 on: 28 January 2017, 23:30 »
Can't say i have had this issue Wrex.My hinges were greased at it's first service in September.
Maybe it's just this?. :undecided:
Current: Golf GTD MK7  3 door manual carbon grey.
Offline gtiaps
« Reply #2 on: 29 January 2017, 11:06 »
As stated will just need a touch of spray grease or wd40 to cure it  :whistle:
2010 Candy White Scirocco 2.0 TDI
2016 Carbon Grey Gti 2.0 Fully Loaded
COLLECTED 29/4/2016 and well pleased with the GTI😆😆
Offline golfhappy
« Reply #3 on: 29 January 2017, 16:34 »
Dracula used to have the same problem when he opened his coffin lid.....spray with white grease!
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline Sootchucker
« Reply #4 on: 29 January 2017, 19:33 »
Check the door sills with car door opened for small scratches. My previous GTD had a drivers door that was hung slightly too low and as such scraped on the VW original (and fitted) door sill protectors. Made a bit of a mess of mine and needed the under surface of the front door reprinting as it had broken the paint and started to spot rust.
To be fair my original GTD was an early 2013 model and I think they have sorted it since. Might be worth checking though if the hinges seem ok ?
Offline Cecil
« Reply #5 on: 11 February 2017, 18:31 »
Mine did the same, a bit of oil followed up by some white lithium grease cured it.
