Author Topic: Sub frame  (Read 3707 times)
Offline robw09
Sub frame
« on: 18 January 2017, 12:09 »
Been advised I have a patch of rot that is close to the suspension arms that would be an MOT failure next time round.
Can the current sub frame be salvaged if the rot is not bad with a rust treatment and seal?
Can a sub frame be welded?
If no to both these how many hours at a garage would it be to replace?  I can see a brand new sub frame is £100
Offline lemski
  • 16v
Re: Sub frame
« Reply #1 on: 18 January 2017, 18:06 »
Not long to do a subframe. 3 or 4 hours should be ample to drop a subframe and seap everything over and fit it back up.
Should be able to clean it up and weld it though dependant on where the rot is.
Only thing that can go wrong is if the nuts in the chasses leg welds brake then you have to pull the carpet up and open the inspection hole to undo subframe nuts.
Offline th3_f15t
Re: Sub frame
« Reply #2 on: 18 January 2017, 22:35 »
It's £105 for a new subframe on eBay, may just be easier to buy a new one and replace it completely..?
Moving over to Flickr, sorry for the broken picture links!
Offline robw09
Re: Sub frame
« Reply #3 on: 19 January 2017, 12:45 »
I am going to replace the frame.  Especially as it has now cracked!
Anything that could be done whilst I am at it?
Offline lemski
  • 16v
Re: Sub frame
« Reply #4 on: 19 January 2017, 13:55 »
Wishbone bushes. Antiroll bar bushes. Steering rack bushes.
Offline robw09
Re: Sub frame
« Reply #5 on: 30 January 2017, 13:28 »
Done, done and done!
Right, next problem is the suddenly developed high idle revs!  :cry:
