Author Topic: Overboost after de-cat full system?  (Read 2740 times)
Offline Ajamesc
« on: 17 January 2017, 18:52 »
Anyone ever herd of this? Since fitting my full miltek system if I drive my car really hard it go's into limp mode. Fault logged was an over boost I was chatting to a local vw guy who also dose ecu maps who said it could be a boost spike due to the free flowing exhaust.
Offline Tezmax
Re: Overboost after de-cat full system?
« Reply #1 on: 17 January 2017, 21:02 »
I suffered an over boost due to a leak via my downpipe/turbo manifold.
Best check for leaks first before spending any cash.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline Ajamesc
« Reply #2 on: 17 January 2017, 21:14 »
Cheers for the reply I'll take a look at that
Offline OSR
« Reply #3 on: 18 January 2017, 11:41 »
Yep my money's on vacuum leak too, had exactly this issue a couple of years ago.
Offline Ajamesc
« Reply #4 on: 18 January 2017, 21:39 »
Turned out to be the dreaded turbo vains not moving I'll give it a good clean remove the egr and fingers crossed all with be good.
Offline Ajamesc
« Reply #5 on: 19 January 2017, 21:41 »
All cleaned up and back together had to remove a lot of carbon from the inlet manifold and egr valve! Turbo vains move nice a free now also fitted a blanking plate to the exhaust manifold under the flexy pipe to the egr cooler so no crap get into the engine!
