Author Topic: Daylight running lights amendment golf Gti mk 7  (Read 3444 times)
Paul larter
« on: 08 January 2017, 13:49 »
Daytime running lights according to the owners manual,  after my previous post I may of mistakingly thought these were the fog lights but according to this extract there are separate lights in the headlights or in the front bumper. When we purchased the car these were in the bumper ( which I assumed were the fog lights) it appears since having some work done this has been reset need some advice on how to get this setting back . Thanks.
Offline vidman2
Re: Daylight running lights amendment golf Gti mk 7
« Reply #1 on: 08 January 2017, 15:38 »
A little confused by your post but, MK7 GTis running lights are U shaped LEDs around the outside of the outside headlight.
There are a number on lighting mods that can be done with VCDS  or ODB11- see the VCDS/ODB11 threads.
Was the WORK you had done by someone with VCDS/ODB11, if so get them to code the lights back to how you want them.
2015 R DSG. Limestone Grey, DCC, Winter Pack, Tech Pack, Reversing Camera    plus   2013 Mk7 GTi DSG - Performance, Navigation, Winter Pack, DCC, Park Assist,
Offline Gnasher
  • Formerly GnasherVXR
« Reply #2 on: 08 January 2017, 18:35 »
There isn't a UK spec (or any other country AFAIK) Mk7 golf that uses the fog lights (or any other light fitted in the bumper) as DRLs. Both the halogen and all varieties of xenon equipped cars have the DRLs in the headlight themselves. If it was using the fog lights as DRLs from the factory, I'd take it back and tell them it was faulty and to fix it under warranty.
Having the fogs on all the time is illegal, inconsiderate and dangerous for other road users. A better idea is to have them come on with high beam - that way you get the benefits of the verges being lit up on country roads etc. but they will go off when you dip your headlights.
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
Offline Finglonga
« Reply #3 on: 08 January 2017, 21:49 »
Have a look under the lighting settings as if you have had some VCDS work done they may have put the option to turn them on of off manually.
Offline dubber36
« Reply #4 on: 09 January 2017, 16:43 »
Some cars use fog lights as DRL's but operating at a lower output. I know on VAG cars with halogen fog lights, it's possible to set them as DRLs and reduce the output using VCDS. Equally it can be done with halogen headlights.
I couldn't agree more with this. In the pre CAN-BUS days, we could easily make this happen with wires and a relay, but those days have long gone.
