Author Topic: mk3 golf 15x8 spacer arch issues  (Read 8495 times)
Offline #projectcrapbox
« on: 07 January 2017, 11:07 »
Hi guys I'm new to the mk3 scene picked up a m reg mk3 1.4 power house for £101 needs sills doing was all, basically using it as a project in two mind what to drop in it or give to the gf for first car as running a b6 Passat myself, basically bought some Stuttgart st4 rims to fit to vehicle there 15x8 have sorted centering spigots etc what I'm so seeing about is the arches if they need Rolling as dropping 30mm on coilovers, and spacers has anyone done this sorry for the newbie question my first mk3 had plenty mk 1,2 and 4 but I'm new to these so Lear I g curve Thanks in advance
Offline lemski
  • 16v
Re: mk3 golf 15x8 spacer arch issues
« Reply #1 on: 07 January 2017, 13:09 »
Think of it as a mk2 as there vertually the same underneath.
To even begin to know what youll need to do youl have to take into acount the offset.
You can bolt a wheel on and look where its sittong. Too far out and you know youll have to roll arches. Camber the wheels in and stretch the tyre.
If its sittong too close to the struts your going to need to space it out. Id go as litle a spacer as you meed as to not cause problems the other side
