Author Topic: Suspension settings  (Read 2666 times)
Offline philstar
  • ...life is all about creating memories...
Suspension settings
« on: 05 January 2017, 13:26 »
I have an '88 16V fitted with Eibach Pro lowering springs (E8509-140) which gives a 20mm drop.
I have Eibach shims to go on the rear - I want to return the car to the original camber and tracking settings that it was at prior to installing the lowering springs.
Does anybody know which numbers I need to align, or should I get the car measured at a garage first then calculate from those measurements and fit afterwards?
I only ask as I have the rear stub axles off at the moment (disassembled to do both rear wheel bearings) so if I can put the shims on now rather than have to strip it all down again that would be lovely.
I have adjustable cam bolts for the front - these will obviously be set at the garage when I get the suspension set up.
Where can I find the original suspension settings for the 16V? Camber, caster and tracking for front and rear?
1988 Atlas Grey VW Golf Mk2 16V GTi [F748 FGT]
Rebuilt: fuel pump housing | suspension | gear linkage | aluminium radiator
Offline lemski
  • 16v
Re: Suspension settings
« Reply #1 on: 05 January 2017, 13:30 »
Go to a tyre place and ask them if they can print off tge settings for factory spec on a 16v. Its what theyd use when tracking ot any way.
