Author Topic: Infotainment box Grrrr!!  (Read 3873 times)
Offline Mike J
« on: 03 January 2017, 11:35 »
Q1; Is it possible to use the Navigation system without having the radio switched on?
Q2; Can I use Lat and Long in the navigation system?    If so how do I input the numbers?
Yes Ive read both books and still cant find the answers........grrrrr!!!
Offline Talk-torque
Re: Infotainment box Grrrr!!
« Reply #1 on: 03 January 2017, 11:43 »
Q1: Not very elegant, but you mute the radio (or media) by turning the volume down to zero. Has the same effect as a proper mute button, in that it also stops any media, such as music from an SD card, running. This then starts up, from where it left off, when you turn up the volume. This also leaves the nav announcement volume unchanged.
Q2: Pretty sure you can, but, without having a fiddle, not sure exactly how. Guessing it's in "options" when you start entering a new destination.
Roger.
Offline silver38
« Reply #2 on: 03 January 2017, 14:32 »
Q2: Yes you can, input GPS coordinates
Try this site for lat. & long. information, very accurate.
http://www.latlong.net/
« Last Edit: 03 January 2017, 20:09 by silver38 »
MKVII GTD Manual - Pure White, 5Door, Adaptive chassis control, Advance telephone connection, Climate comfort windscreen, Discover Nav pro, High beam assist, Keyless entry, Sport and Sound pack, Park assist system with steering assist, Rear view camera, Rear side airbags with rear seatbelt warning, Winter pack, 5 Year Warranty
Offline Mike J
« Reply #3 on: 04 January 2017, 09:00 »
Thanks for your quick replies guys.
Q1: I had worked it out that turning down the volume worked but assumed such a sophisticated box of tricks would have something far better.
Q2: Mmmm so its back to fiddling with the buttons  :cry:
When in remote areas on the Continent I find being able to use the accuracy of Lat/Long is a distinct advantage, even some locations in the UK are better located using numbers rather than a generalised post code.
Thanks again. :smiley: 👍
Offline Mark V GTD
« Reply #4 on: 05 January 2017, 07:50 »
I find the basic VW nav system more often than not will not even accept the full postcode - its a pretty useless piece of kit (and mine is a MIB2)!
Offline p3asa
« Reply #5 on: 05 January 2017, 10:47 »
Are you making sure you put a space between the first group and the second?
Offline Talk-torque
« Reply #6 on: 05 January 2017, 17:53 »
There do seem to be too many postcodes that are simply not in the Discover Nav database, such that the keyboard refuses the option of any input after the first few characters. I've had, what should be, postcodes treated that way, as well as obvious new ones. Could it be that the outfit who provide the Nav data are penny pinching on who they buy this from?
Roger.
Offline Mark V GTD
« Reply #7 on: 06 January 2017, 16:56 »
Hmm, not sure - I will check now!
Update - wow that worked!  Although it took me to a spot on a road just outside the next town!
Thanks for the info - no idea that you had to go back from 'input numbers' to 'input letters', hit the space bar and then back to the 'input numbers' page - unbelievably fiddly but it does allow it. Shame about the accuracy though!
« Last Edit: 06 January 2017, 17:05 by Mark V GTD »
Offline silver38
« Reply #8 on: 06 January 2017, 18:37 »
Try with GPS coordinates, more accurate and as easy to input.
Offline fredgroves
« Reply #9 on: 06 January 2017, 19:05 »
Designed for German postcode format...
