Author Topic: Alternator light  (Read 2784 times)
Offline Wrex22
Alternator light
« on: 25 December 2016, 22:38 »
Noticed today that when I switch the ignition on there isn't a battery alternator light
Offline golfhappy
Re: Alternator light
« Reply #1 on: 26 December 2016, 09:22 »
Just as a check stick a meter on the battery with the ignition on and the car off, then check again with the car on, then stick the lights on and maybe the AC. You'll be something like +12 then +14 then with load it should then start to drop if that make sense.
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline Talk-torque
« Reply #2 on: 26 December 2016, 10:17 »
Don't connect anything across a battery, unless you know exactly what you are doing!
Roger.
Offline golfhappy
« Reply #3 on: 26 December 2016, 11:10 »
True...don't poke anything unless you know what your doing.
Offline TwoSheds
« Reply #4 on: 26 December 2016, 11:49 »
Not every warning light is displayed during ignition on.
The alternator fault light I suspect illuminates when there is an actual fault ( battery symbol).
Offline golfhappy
« Reply #5 on: 26 December 2016, 20:05 »
True, my check was to make sure the alternator was working.
