Author Topic: R32  (Read 2250 times)
Offline jonesltd
  • MK7 R
R32
« on: 23 December 2016, 11:39 »
Looking at a few r32's but always had diesels so first for a petrol. I always know diesels are still classed as new engines even 93k however I don't know about petrol? Looked at 1 with 93k  and another 117k....ranging 5-7k.
Do I avoid? When do petrol engines start to die or have problems? Or are they the same as diesels they keep going as such?
If you cant find it......Grind it
Offline brettblade
Re: R32
« Reply #1 on: 23 December 2016, 11:47 »
All down to correct maintenance.  Diesels lasting longer than petrols is a myth in my experience, it just so happens that due to better MPG that diesels are more likely to be seen with higher mileage - reinforcing the "they last longer" image.
Orded 04/06/2016
Build W/C 01/08/2016
Handover 01/09/2016
GTI PP, CSG, Tech pack, parking pack, 90% tints, DCC, 19" Santiago alloys
Soon to be gone!
7.5R Indium Grey, 19” Spielbergs expected 01/03/2019.
Offline jonesltd
  • MK7 R
Re: R32
« Reply #2 on: 23 December 2016, 11:54 »
Oh OK fair enough. This has full service history the 93k
Offline lemski
  • 16v
Re: R32
« Reply #3 on: 23 December 2016, 14:34 »
As far as im aware the vr timing chains are due around 100k so aslong as theyve been done or you factor the cost into buying 93k with full service history could be a good buy
Offline Nino
  • Insta - F6UGA
Re: R32
« Reply #4 on: 23 December 2016, 19:35 »
Sorry mate, this is incorrect.
I am a current owner of an R32 (my 2nd one) the timing chains requiring to be changed is purely a scare, they are only required IF they are outside of tolirence.
This can be measured using Vagcom, measuring blocks 208 & 209 while the engine is running.
The tolorence is anywhere between +9 & -9, once they hit -/+ 10 it will trigger the engine management light.
I had mine done purely because I needed a new slave cylinder (which is located inside the gearbox) so I had the timing chains, sprockets, guides, all gasgets, clutch & flywheel done at the same time.
In terms of the mileage, as long as it has FSH and has had The heldex oil changed every 20k miles and oil & heldex filet every 40k and normal oil changes every 12months or 10k miles, it should be fine.
When you test drive one, ensure that you red line a few gears and pay close attention to the behaviour of the clutch pedal, if it returns slowly or seems LAZY walk away.
Current - MK6 GTi Edition 35 - Candy White - 3 door.
