Author Topic: Golf Mk7 Clubsport S Part Numbers  (Read 33345 times)
Offline TurboTrev
Re: Golf Mk7 Clubsport S Part Numbers
« Reply #20 on: 07 December 2016, 15:27 »
It looks like the seat base and seat back are the only parts sold for the padded areas, so if the lower side bolster wears you need a seat base, and the same for the upper bolster.
The part number for the base is 5G0881375AD and its not a bad price £88 but the upper part is priced on application
I will post a pic up later this eve showing the part I mean
Thanks.
Jackie Treehorn
« Reply #21 on: 07 December 2016, 17:46 »
Offline TurboTrev
« Reply #22 on: 07 December 2016, 17:57 »
^^^Many thanks JT.  Have you had a chance to look at the difference in the exhaust systems of a CS and CSS?  Cheers.
Jackie Treehorn
« Reply #23 on: 07 December 2016, 18:59 »
Should be added to the front page of this thread soon including the CS rear brace and net :wink:
Offline TurboTrev
« Reply #24 on: 07 December 2016, 19:16 »
^^Thanks, you're doing a grand job. :smiley:
Offline Tornado8
« Reply #25 on: 07 December 2016, 19:23 »
Good post. Now I know I might be asking too much but I think it would be interesting to a lot of us to have the same list for the Clubsport and thus pinpoint unknown CS/CS-S differences or similarities. The other day I measured the rear arb on my CS and found it to be between 21.5-22mm so it seems as both CS variants share the same item in terms of rarb.
As an aside just fitted Neuspeed rear ARB 25mm The turn in is much improved and feels much more stable :smiley:
Old, but a serial modder!
Offline Sean G
« Reply #26 on: 07 December 2016, 19:52 »
Can you check and see if Mudflaps are listed for the CSS
Offline scanesare
  • GTI Clubsport
« Reply #27 on: 07 December 2016, 21:44 »
if you let me have a reg of a CS with active dampers I can check.
I can say that the non adaptive CS and non adaptive GTI PP are the same.
Front 5Q0413031FN
Rears  5Q0513029GL
I don't have a UK car but I just found this from a VW ad: LC66WYW (CS with DCC)
In principle they should be the same as the only difference should be in springs (at least according to the CS-S press release) but you never know...
Have to say what I great thread and respect to you for the time you spend on it. Makes a CS to CS-S project a very simple job for whoever is after it. That was actually my plan before getting my CS (track down suspension differences and replace all the CS-S bespoke items) but it honestly feels so good as it is (much much better and balanced than all previously suspension tuned cars I had) that I don't think I will bother for a mere 3-4 trackdays per year.
Offline dave7268
« Reply #28 on: 07 December 2016, 22:13 »
Would like to know the part number for the CS DSG gear knob please - just love those red accents on it  :wink:
7GTI PP DSG - no longer
Jackie Treehorn
« Reply #29 on: 08 December 2016, 11:39 »
@ Sean G Mudflaps are the same as GTI (dont let Booth on here see you ask for this  :wink:)
@scanesare CS and CSS active dampers are the same 5Q0413031ED
@ Dave7268 DSG Clubsport gear stick 5G1713203Q
« Last Edit: 08 December 2016, 21:46 by Jackie Treehorn »
