Author Topic: Golf Mk7 Clubsport S Part Numbers  (Read 33385 times)
Jackie Treehorn
Re: Golf Mk7 Clubsport S Part Numbers
« Reply #10 on: 07 December 2016, 12:11 »
Can you get a part number for the cover inside the car that goes over the rear seat void?
I can find every part (trim,bodywork,seats, sound insulation) except the carpet that covers that area on the CSS, how strange... :angry:
Offline Gnasher
  • Formerly GnasherVXR
« Reply #11 on: 07 December 2016, 12:18 »
Quick question - are the calipers and hubs the same on the CS-S and GTI PP?
If so, that would (hopefully) open up the chance of replacing with CS-S discs once worn.
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
Jackie Treehorn
« Reply #12 on: 07 December 2016, 12:20 »
Good post. Now I know I might be asking too much but I think it would be interesting to a lot of us to have the same list for the Clubsport and thus pinpoint unknown CS/CS-S differences or similarities. The other day I measured the rear arb on my CS and found it to be between 21.5-22mm so it seems as both CS variants share the same item in terms of rarb.
CS rear ARB is same as PP, only the CSS has the thicker 3.6mm rear ARB. they are all 21.7mm dia
Clubsport VS GTi PP
Sway Bars
CS = 5Q0411303N front anti roll bar (sway bar) 24mmx 3.8mm (same as GTI PP)
CS = 5Q0511305AT Rear anti roll bar (sway bar) 21.7 x 3mm (same as GTI PP)
FRONT SPRINGS 5Q0411105GD (GTi PP 5Q0411105CC)
FRONT SHOCK 5Q0413031FN (same as GTI PP)
STRUT MOUNT 5Q0412331D (same as GTI PP)
BUMPSTOP 1K0412303F (same as GTI PP)
REAR SPRING 5Q0511115HL (GTi PP 5Q0511115HM)
REAR SHOCK 5Q0513029GL (same as GTI PP)
I see, thanks.
Can you also provide the item numbers for adaptive dampers between PP, CS, CS-S?
if you let me have a reg of a CS with active dampers I can check.
I can say that the non adaptive CS and non adaptive GTI PP are the same.
Front 5Q0413031FN
Rears  5Q0513029GL
Jackie Treehorn
« Reply #13 on: 07 December 2016, 12:26 »
The calipers are the same (part number on previous page are the same for both).
The hubs are different and so are the bearings, will the discs mount the same?  You guess is as good as mine, but i wouldn't want to try it with my own money as i bet a special order at VW is non returnable...
Offline Gnasher
« Reply #14 on: 07 December 2016, 12:29 »
Aha, wasn't sure if they were CS or CS-S part numbers.
Like you say, I'll let someone else take the risk before going for it myself  :wink:
Jackie Treehorn
« Reply #15 on: 07 December 2016, 13:37 »
yeah I was thinking the same,
But think i will pick up the rear ARB its about 15% thicker so will be stiffer i hope...
Offline LRWmotorsport
« Reply #16 on: 07 December 2016, 14:23 »
Meanwhile at the Ring:
"How do we make the a**e step out Karsten?"
"Wheel Frequency = 0.5 Pi by route K over M...... actually just add some roll bar Fritz, that'll make him hold on tight"
Could be a Ginetta paddock (sorry Simon).
2015 BRSCC PGTI Championship 2nd #55
2016 BRSCC PGTI Championship 2nd (again) #25 & BARC Intermarque
2017 BRSCC PGTI CHAMPIONS #24
Offline TurboTrev
« Reply #17 on: 07 December 2016, 14:32 »
If you have a moment JT, I would be grateful to know whether the recaro bucket seat covers in the CS are one piece or whether you can order separate bits?  In particular, could I order the right side bolster covers on the driver's side (base and back), together with the foam that goes in them?  If so, I would be grateful for the part numbers - I'm anticipating that they will wear very quickly so I would like spares!
Also, what are the differences between the CS and CSS exhaust systems?
Many thanks.
« Last Edit: 07 December 2016, 15:44 by TurboTrev »
Jackie Treehorn
« Reply #18 on: 07 December 2016, 15:16 »
 :grin:
Jackie Treehorn
« Reply #19 on: 07 December 2016, 15:17 »
It looks like the seat base and seat back are the only parts sold for the padded areas, so if the lower side bolster wears you need a seat base, and the same for the upper bolster.
The part number for the base is 5G0881375AD and its not a bad price £88 but the upper part is priced on application
I will post a pic up later this eve showing the part I mean
