Author Topic: How to make a 1.8 quick  (Read 3670 times)
Offline Andy grim
« on: 19 November 2016, 21:22 »
Hi got a 1.8 how do I make it quicker
Offline itavaltalainen
Re: How to make a 1.8 quick
« Reply #1 on: 20 November 2016, 14:36 »
By buying another car - they are not quick but reliable though.
To make it faster you'd spend more than the car's worth (multiple times!)
Offline madmanmart
« Reply #2 on: 20 November 2016, 14:43 »
Tow it with a Vr6
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline Walshy155
« Reply #3 on: 20 November 2016, 17:29 »
I'm going to turbo mine at stock compression run about 4 psi or less, I've already designed a home made pulse width generator with adjustable frequency to plumb an extra 3 bar injector in which will be programmed to ramp up and down on and off boost although it will probably go bang in the end. Then hunt for a vr6 or ABF lump
Offline gasketface
« Reply #4 on: 21 November 2016, 09:02 »
Put the wrong clocks in it,something that shows 60mph when you are really only doing 30.
Offline gazareth
« Reply #5 on: 21 November 2016, 20:17 »
find a really steep hill, and floor it down to the bottom :grin:. on a more serious note. it ain't even worth trying i'm afraid.
Offline gazareth
« Reply #6 on: 21 November 2016, 20:19 »
to make any golf quicker, you need to start with one that has 4 fuel injectors :wink:
