Author Topic: Glovebox light  (Read 2970 times)
Offline m19ads
Glovebox light
« on: 12 November 2016, 13:32 »
Hi
Random one but can someone confirm that a may 2016 golf gti should have a working light in the glove box? Realised mine was working now we have dark nights. Took it out and found I have no wiring gong to it!! I have had a new dash and control module for head unit so glove box was taken out. I'm assuming it should work and perhaps wiring loom is trapped someone where!!
Ads
On Order Golf GTI 5 door Tornado Red Performance Pack 19inch Santiagos Build week 11/4 currently in transit..........
2014 VW Touran SE
2004 BMW 325CI Convertible
2005 Golf GTI 5 door Black (favourite car to date)
2006 VW Touran Sport
2002 Golf GT TDI 130
Loads of non VW stuff that I don't want to confess too!!!
Offline gtiaps
Re: Glovebox light
« Reply #1 on: 12 November 2016, 14:27 »
Hi yeah if the light is there it should be working as you say the glovebox has been out so guessing it's not been plugged back in.
Mines a April 2016 Gti with light iv just swapped it out tor the led light from one side of the footwell and put red leds instead of the standard white  :whistle:
2010 Candy White Scirocco 2.0 TDI
2016 Carbon Grey Gti 2.0 Fully Loaded
COLLECTED 29/4/2016 and well pleased with the GTI😆😆
Offline Finglonga
Re: Glovebox light
« Reply #2 on: 12 November 2016, 14:40 »
The plug does disappear into the hole at any chance it gets. Try a firk with your finger to see if you can find it.
Offline gtiaps
Re: Glovebox light
« Reply #3 on: 13 November 2016, 09:03 »
« Last Edit: 13 November 2016, 09:05 by gtiaps »
Offline GeoBog
Re: Glovebox light
« Reply #4 on: 14 November 2016, 22:02 »
Can confirm that there is a working light in the glovebox on 2016 GTIs. The cable is pretty short to be fair so if you had work done in that area there is high chance it's tucked in somewhere inside the dash and the guy that worked on your car has not bothered to connect it back. On my previous 2014 GTI the cable was even shorter, I could barely take it out to change the bulb with a LED bulb.
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline Mike J
Re: Glovebox light
« Reply #5 on: 16 November 2016, 09:22 »
Where are you guys buying your LED bulbs?
At £12 odd for a single festoon to go in the boot its going to cost a bit to do the upgrades mentioned on here.
Offline Finglonga
Re: Glovebox light
« Reply #6 on: 17 November 2016, 11:01 »
I got mine from Horizon LEDs as well as the Boot and sun visor ones (different sizes).
Offline gtiaps
Re: Glovebox light
« Reply #7 on: 17 November 2016, 14:38 »
Footwell red leds came a flee bay seller in Enfield ☺
Offline Mike J
Re: Glovebox light
« Reply #8 on: 17 November 2016, 19:09 »
Thanks guys 👍
