Author Topic: Power steering oil top up  (Read 3921 times)
Offline Tezmax
« on: 07 November 2016, 05:14 »
Hi all,
Last week on a few occasions I heard a whirring, humming coming from my power steering when on full lock doing a slow turn. I've been told it may just need some oil, is this a possibility and if so where do you top it up. If not is it going to be expensive.
Thanks in advance.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline jv
  • Administrator
Re: Power steering oil top up
« Reply #1 on: 07 November 2016, 13:05 »
Yes. Left of the engine in front of the coolant if I remember correctly.
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Rhyso
« Reply #2 on: 07 November 2016, 14:48 »
9/10 times you are going to need a new rack  :sad:
Offline Tezmax
« Reply #3 on: 17 November 2016, 07:29 »
Thanks for the info.
Oil level was only just touching tip of dip stick which is well below minimum.
hopefully it won`t get any worse other than a slight whine on the cold mornings approaching  :wink:
Tezmax.
Offline barrym381
« Reply #4 on: 17 November 2016, 17:16 »
Make sure you put the right fluid in as I have just picked up a mk4 that the owner thought it was ok to just throw brake fluid in  :laugh:
Offline lemski
  • 16v
« Reply #5 on: 18 November 2016, 12:30 »
For fluid its the green mineral stuff.
Apparently normal fluid or atf fluid will kill the pump off quick
Offline bgbazz
  • If it aint broke...I can fix it!
« Reply #6 on: 18 November 2016, 16:10 »
If the normal or ATF are bad for the pump, I shudder to think what brake fluid would do.
 :rolleyes:
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
Offline lemski
  • 16v
« Reply #7 on: 18 November 2016, 16:41 »
Not worthe thinking about really is it
Offline bgbazz
« Reply #8 on: 18 November 2016, 18:59 »
No, probably not, but one wonders where the owner gathered enough brain cells to ever get a drivers licence...presuming he ever held one.
Offline lemski
  • 16v
« Reply #9 on: 18 November 2016, 19:09 »
Back of a cereal box :laugh:
I cant quite believe someone would think brake fluid will work
