Author Topic: Brake pad light..Golf GTTDi 2005 ( BKD )  (Read 4257 times)
Offline greg1953
« on: 05 November 2016, 21:01 »
Brake pad wear light has come on but I've had new pads in the front since August, still good. I disconnected the plug on the pass. side front pad but the light stayed on, is there a wear indicator on the rear pads ?
Greg
Offline itavaltalainen
Re: Brake pad light..Golf GTTDi 2005 ( BKD )
« Reply #1 on: 06 November 2016, 13:17 »
Of course the light stayed on - the circuit is open....
Tears may have wear sensor, would suggest you take wheel off and look for wire to brake pad.
Offline lemski
  • 16v
« Reply #2 on: 06 November 2016, 19:17 »
Easiest way to see if ita wiring is unplug and bridge the connector with a paper clip or something. Completing the. Ircuit
Offline greg1953
« Reply #3 on: 06 November 2016, 19:23 »
Soon as it stops raining I'll try that.
Greg
Offline Teutonic_Tamer
« Reply #4 on: 29 November 2016, 16:21 »
Rears do NOT have wear sensors.
As itavaltalainen states, by unpluging the front sensor, you will trigger the warning light!  Reconnect the plug - but check carefully for any damage to the wiring.  Non-genuine pads are frequently prone to breakpad wear sensor failure (and OEM can fail too, if handled roughly).  Also check for any corrosion within the electrical connector, and ideally seal and protect the connector with a smear of silicone grease inside the connector.
I feel like a homo
