Author Topic: Mk4 golf gti boost problems  (Read 2196 times)
Offline Newbie gti Nick
« on: 05 November 2016, 07:48 »
I'm new to all this so apologies up front.
I have recently purchased a 1.8t aum mk4 golf.never owned a turbo before.
It was having idle problems. It has had a new maf fitted pcv bypass and n249 bypass. Ran well for a week.
Now boost seems lower,but if you lift off throttle and push back down it'll boost higher each time untill the boost gauge just passes 0.5bar then the needle sort of chatters there untill lift off!(Sounds weird). It also seems to be releasing to atmos(standard dv) sometimes it's jumpy through the revs when reaching 3k upwards.
Could this be the n75 valve?
Help would be hugely appreciated.
Offline lemski
  • 16v
Re: Mk4 golf gti boost problems
« Reply #1 on: 05 November 2016, 13:07 »
 Have you scanned.
Id swap out the recerc valve for another to rule that at
Offline LR5V
« Reply #2 on: 05 November 2016, 15:46 »
Yes - scan and check all your pipes:
breather -they dissolve from the inside out
vacuum -just turn to dust
boost  -dependant on your engine the spigot joints start to leak
« Reply #3 on: 05 November 2016, 15:52 »
Thanks for reply.I took the dv off and checked it by sticking a 3/8 ext bar in it and finger over the top and the vacuum seems fine. Have a cheap scanner the only code I seem to have now is the dreaded 17705 leak between turbo and dv. But before that I've had these which aren't coming up anymore 17545 and 16795. But drove fine even with these. The bottom oil breather seal was leaking so I replaced that.
Offline lemski
  • 16v
« Reply #4 on: 05 November 2016, 16:00 »
Id try a dif dv. Or be checking all clamps and vac pipes.
« Reply #5 on: 05 November 2016, 16:27 »
I'll order one up and give all the pipes another good check over.
