Author Topic: HELP AND ADVICE please Mk4 1.8turbo  (Read 1750 times)
Offline MrBrierley
  • Needing some help for my 1.8T
« on: 04 November 2016, 02:27 »
Ayup guys,  I have got a mk4 with a 1.8t lump conversion was running mint been a good car had loads of money spent on it absolutely love it,  but I went out to it the other day to put a new (actuator)  on I couldn't get to the last blot under the manifold so I put all my boost pipes and actuator back on,  went to start it and nothing.  I left it over night it fired up let the turbo warm up went to move it and it cut out again and won't start at all now, I removed coil 2/3 and there was no spark...  I've been told it's a million and one things but does anyone have any thoughts that could help me I'm stuck...  I have double checked all plugs/fuses /relays and there fine also no Fault codes are being read when I've plugged it in PLEASE HELP I'Mat my whitts end.  Thanks in advance
MrBrierley :)
Offline lemski
  • 16v
Re: HELP AND ADVICE please Mk4 1.8turbo
« Reply #1 on: 04 November 2016, 18:40 »
What engine code.
Have you swapped the coilpacks around with the working ones see if the spark is there then.
Imobiliser cutting in?
Lastly ign amp (agu)
