Author Topic: Rear Suspension top mount Repairable Or Not  (Read 2580 times)
Offline pickles
  • Next!!!
« on: 29 October 2016, 15:08 »
[imghttp://][/img]
[/URL][/img]
[/URL][/img]
Had a horrible sound one night, found out to be the rear suspension top mount had broken. Is this even repairable lol . cant see the other pics but the left bolt, where it screws into has corroded and is no longer there if you know what i mean .
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline pickles
  • Next!!!
Re: Rear Suspension top mount Repairable Or Not
« Reply #1 on: 29 October 2016, 15:17 »
Mapped
Nearly S3 time  :)
Offline itavaltalainen
« Reply #2 on: 03 November 2016, 11:22 »
What do you want to repair?
They will need to be replaced.
Offline pickles
  • Next!!!
« Reply #3 on: 03 November 2016, 23:23 »
i got a new top mount and done a quick nut n bolt job with some threaded rod  :grin:, just wondered if some kind of captive nut could be welded in place where the original has corroded.
Mapped
Nearly S3 time  :)
« Reply #4 on: 04 November 2016, 08:23 »
I would recommend you replace all the bolts with the specified ones from VW - they are deforming when tightened correctly.
Yes a new one can be welded in.... but it needs to be high strength. Iirc they are all 10.9
