Author Topic: Fuel flap wiring?  (Read 1690 times)
Offline Ajamesc
Fuel flap wiring?
« on: 27 October 2016, 16:27 »
Anyone know how it's wired? My solenoid is fine it works when you put 12 volts to it. The switch has 12 volts at it on the yellow wire / brown wire. When you push the switch one of the blue wires with a tracer has 12 volts on it the other one seems to do nothing? Un less that's the lighting wire to light it up I did not check that. Anyway I only have about 6/7 volts at the solenoid so it will not move.
Offline Ajamesc
Re: Fuel flap wiring?
« Reply #1 on: 29 October 2016, 18:37 »
Fixed it in the end only had 9v getting to the solenoid. 4th with in the switch is to light the bulb. Ran a new signal wire from the switch to the solenoid works fine now
