Author Topic: N75 Hose dimensions for manual boost controller  (Read 2867 times)
Offline Ainsleyg1981
« on: 26 October 2016, 18:18 »
Hi all
I'm wanting to fit a manual boost controller on my AGU 1.8t I want run it in parallel with the n75 valve, my question is does anyone know the size of the hose that connects to the n75 valve as I need to get a reducer as the hose size that connects to the mbc is 4mm (vacuum hose)
Thanks in advance chaps.
Ainsley
« Last Edit: 26 October 2016, 18:27 by Ainsleyg1981 »
Offline barrym381
Re: N75 Hose dimensions for manual boost controller
« Reply #1 on: 26 October 2016, 18:51 »
Just use your right foot to control the boost  :smiley: forget the manual stuff
« Reply #2 on: 26 October 2016, 18:57 »
Nice idea if it has more than 0.5 bar that's wank! My wife's diesel touran is faster. Even 1bar would be nice save it feeling like a Nissan Micra
Offline barrym381
« Reply #3 on: 26 October 2016, 19:52 »
A mapped diesel will feel faster even if you have 1bar of boost  :smiley:
Offline lemski
  • 16v
« Reply #4 on: 26 October 2016, 21:37 »
5 or 6 mm.
Wouldnt personally get a boost controller over having the aum mapped but each to there own.
Offline barrym381
« Reply #5 on: 26 October 2016, 21:42 »
5 or 6 mm.
Sure his car is an agu  :smiley:
« Reply #6 on: 27 October 2016, 06:28 »
5 or 6 mm.
Neither would I but I can't stand it being so slow in standard trim and a boost controller if installed correctly to run parallel with the n75 will possible double my boost for £25. As I have the old throttle cable engine a remap is £350. Which I don't have at the moment.
Offline lemski
  • 16v
« Reply #7 on: 27 October 2016, 13:14 »
I see your point.
5mm will do it fine
