Author Topic: Bulb for bi-xenon headlight (and fitting)  (Read 11577 times)
Offline Hawaii-Five-O
  • Are we nearly there yet?
« on: 24 October 2016, 10:11 »
On the way to work this morning I got a warning light on dash telling me that my right front dipped headlight bulb has gone. Checked when I parked up and it has indeed gone.
Now then, which bulb do I need to replace it?
Code number?
Can I replace it myself?
Thanks
« Last Edit: 24 October 2016, 12:03 by Hawaii-Five-O »
Current: BMW M140i / ZF8 / 5 DR
Past: MK7 GTI / DSG / WHITE / 5 DR
Offline dubber36
Re: Bulb for bi-xenon headlight
« Reply #1 on: 24 October 2016, 10:36 »
You need a DS1 xenon bulb www.autobulbsdirect.co.uk/replacement-d1s-xenon-hid-bulbs/
To replace it you need to remove the headlight and in order to do that, remover the bumper.
« Reply #2 on: 24 October 2016, 10:40 »
Thanks Dubber.
Bloody hell I've got to remove the bumper to get to headlight!!! Know any good how to guides on the interwebs?
I've got my MOT on Saturday morning and if I don't change the bulb it will fail. Arrgh
Offline clubsport
« Reply #3 on: 24 October 2016, 11:06 »
Best of luck sorting it HF0, hope it is less hassle than it sounds.
If I ever have this issue, do you need to use a Vag.com to reset or align the headlight, or just to clear the warning light on the dash?
« Reply #4 on: 24 October 2016, 11:21 »
Cheers fella. It's a bummer for sure.
Do most people just take it to the dealers?
Offline Gnasher
  • Formerly GnasherVXR
« Reply #5 on: 24 October 2016, 11:27 »
Can't remember 100% which one but I'm pretty sure they are either DS2 or DS3 bulbs from when I changed mine...
Link to the How-to I wrote...
http://www.golfgtiforum.co.uk/index.php?topic=270994.msg2482858#msg2482858
Hope that helps!
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
Offline Gnasher
« Reply #6 on: 24 October 2016, 11:35 »
Offline dubber36
Re: Bulb for bi-xenon headlight (and fitting)
« Reply #7 on: 24 October 2016, 12:09 »
It seems that it's best you check the bulb type before you order, as Autobulbs and Powerbulbs show different types.
Offline fredgroves
« Reply #8 on: 24 October 2016, 13:18 »
My local dealer doesn't charge to fit bulbs. You might want to ask yours...
That probably means that a 60 quid bulb from the internet is 100 quid from them, but...
Offline itavaltalainen
« Reply #9 on: 24 October 2016, 14:15 »
Bumper does not need to come off - you can remove wheel arch lining. Not even the headlight needs to come out.
I would swap both at the same time.
Look here for a guide:
http://www.motor-talk.de/forum/aktion/Attachment.html?attachmentId=733971
