Golf mk3
hardmonkeys
Convertible roof pump bleeding
Topic: Convertible roof pump bleeding (Read 3542 times)
Valere Oddoux
18 October 2016, 11:18 »
Hi,
Does anyone knows how to bleed the air out of the convertible roof pump.
Regards
gasketface
Re: Convertible roof pump bleeding
18 October 2016, 19:45 »
Open bleed valve and open and close roof manually a few times.Job done.
Valere Oddoux
23 October 2016, 22:07 »
Thanks Gasketface,
Where's the bleed valve...
gasketface
27 October 2016, 19:42 »
Lol.If you look at the pump in this ad :-
http://www.ebay.co.uk/itm/VW-Golf-Convertible-Cabrio-Mk3-Mk3-5-Mk4-2-0-powerpacker-roof-pump-1E0871791A-/272337723799?hash=item3f6897e197:g:tcoAAOSw65FXrFGU
See where it says "max" on the pump,to the left of pic ?.Just right of that is the bleed valve,it's like a "T" shape sticking out.Just undo that clockwise a couple of turns and then operate the roof manually a few times and do it up again.Check the level as well.
Pump on UK models is on the left as you look into the boot.You can access the bleed valve which is under a round rubber grommet/cover about 70mm in diameter.
Valere Oddoux
02 November 2016, 12:47 »
Thanks gasketface, appreciated.
I call that the release valve, I have changed two roofs and two sets of hydraulic lines but always wondered how to bleed the air off, didn't think that would do it.
Golf mk3
hardmonkeys
