Author Topic: power steering rack  (Read 1957 times)
Offline gamestaffords
power steering rack
« on: 17 October 2016, 17:40 »
hi, i think my rack is leaking is there an easy fix or is it a new rack?
so if a new rack is needed how hard are they to change?
Thanks Ross
Offline lemski
  • 16v
Re: power steering rack
« Reply #1 on: 18 October 2016, 09:54 »
Not too difficult.
Straighten steering wheel, inside the car theres a 13mm that holds the column to the rack. Undo that.
Jack car up
Undo dogbone mount, ball joints (id leave the joints in the hubs and undo the 3 13s on either side
Undo the subframe. If you have level sensors for the headlights theyll have to be taken off the lower arm.
Now you will see where the power steering pipes go into the rack. Undo them and then... Undo the 4 nuts that hold the rack.
Fitting is reversal.
« Reply #2 on: 18 October 2016, 14:25 »
Thanks pal awesome write up much appreciated
Offline lemski
  • 16v
« Reply #3 on: 18 October 2016, 14:33 »
Its off the top of my head from 4 years ago. But the main jist is there.
Might turn out the washers where the pipes go in just need sorting.
I cant see the car so only speculate
Offline Rhyso
« Reply #4 on: 18 October 2016, 19:03 »
If the rack itself is leaking you'll need a new one or a refurbished one  :sad:
