Author Topic: Sump plug help!  (Read 2925 times)
Offline joe6
Sump plug help!
« on: 17 October 2016, 14:05 »
Just going to do my intermediate oil change and general VCDS check and found that the sump plug fitted at the last full service is the type with a splined insert in the plug instead of the previous bolt head type. Can anyone help with the spline size please?
Offline joe6
Re: Sump plug help!
« Reply #1 on: 19 October 2016, 19:50 »
Sorted it myself. Went to VW dealer to get a new sump plug - first time I have been given anything by VW dealer!! On checking the spline fitting found I had the required T45 star socket bit (6 point) in my toolbox. Job now done :smiley:
Offline The ANT
Re: Sump plug help!
« Reply #2 on: 19 October 2016, 22:50 »
Torx?
Suffering from a severe and unforgiving case of GTItis
Offline joe6
Re: Sump plug help!
« Reply #3 on: 20 October 2016, 16:27 »
Offline Keithuk
Re: Sump plug help!
« Reply #4 on: 30 December 2016, 13:47 »
I've always brought a new sump plug from my dealer when I've done an oil & filter change. Its always been an hexagon. The other thing is it has a steel washer not Copper, Aluminium or Fibre which is total crap for a drain plug.
Sealing bolt with sealing ring - N908 132 02 - £2.62
The same sump plug is fitted to 330 VAG models.
http://nemiga.com/cat_spares/etka/volkswagen/go/686/103050/
ETKA doesn't show a Torx only an hexagon.
Keep http://nemiga.com/cat_spares/etka/volkswagen/ in your favorites/bookmarks.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
