Author Topic: Mk4 central locking  (Read 2052 times)
Offline Ajamesc
Mk4 central locking
« on: 16 October 2016, 18:31 »
Hi new to golfs just got a mk4 gt tdi 150. The passenger door will not lock or un lock with the central locking any ideas guys
Offline lemski
  • 16v
Re: Mk4 central locking
« Reply #1 on: 16 October 2016, 18:35 »
Door module unplugged. Possibly because the microswitch has gone and says the doors open all the time.
Can scan with vag com to check.
Or if you press the lock Bitton on drivers door and it locks unlocks it means door module still plugged in
Offline Ajamesc
« Reply #2 on: 16 October 2016, 19:07 »
It doesn't lock or un lock with the master button on the drivers door. Can you replace the micro switich and wear is it located mate
Offline lemski
  • 16v
« Reply #3 on: 16 October 2016, 22:23 »
In the door module, sound like its unpligged because the micro switch is gone. If you know someone with vagcom they can check that, or pull the door card off and if its unplugfed thatll be why. My passat drivers door was unplugged because of this issue and now always tells me.the door is open.
Ill one day change the microswitch. But its not a bother now
Offline itavaltalainen
« Reply #4 on: 17 October 2016, 10:17 »
Pain to remove the lock - all else needs to be gutted first.
As for a scan with VCDS that's what I'd do as a first step too. I might be able to do for you, depending on where in the country you are.
