Author Topic: Wheels and Steering wheel alignment  (Read 3157 times)
Offline RossJames
« on: 24 October 2003, 13:20 »
Just had a new steering wrack fitted and the garage told me they didn't have the equipment to align the wheels which isn't a problem as this can be done anwhere,  but the sterring wheel is out as well and has an air bag.....is this a main dealer job ?
golfvr6
Re:Wheels and Steering wheel alignment
« Reply #1 on: 24 October 2003, 13:56 »
Get the wheels properly aligned, then take the battery negative off. Take out the 2 side bolts on the back of the airbag, remove it. Undo the centre bolt that holds on the steering wheel, then re-align the steering wheel as required. Make sure that after you have refitted the airbag that there is no-one in the car when you reconnect the battery negative(in case it goes off).
Offline RossJames
« Reply #2 on: 24 October 2003, 14:57 »
and if it goes off ?  :-[
Offline sKrEwBaLL
« Reply #3 on: 24 October 2003, 14:58 »
Run
golfvr6
« Reply #4 on: 26 October 2003, 18:58 »
I doubt it will go off, its just a precaution.
