Author Topic: Engine noise  (Read 5189 times)
Offline Marjon99utd
Engine noise
« on: 10 October 2016, 19:18 »
Had the car a few months but engine noise doesnt seem right. It seem to be getting a worse but i cant really explain the noise....
Its a used car but its under warrenty.
If i book the car in and there is nothing wrong with it will i be charged?
Thanks
Offline SunnyGTI
Re: Engine noise
« Reply #1 on: 10 October 2016, 21:18 »
Is the warranty with VW?
Some garages charge for diagnostics if it's not a fault covered by warranty
Can you see where the noise is coming from? Could it be a faulty injector..? Is the car running ok...just noisy?
Offline The ANT
Re: Engine noise
« Reply #2 on: 10 October 2016, 21:36 »
What sort of noise?
Suffering from a severe and unforgiving case of GTItis
Offline Marjon99utd
Re: Engine noise
« Reply #3 on: 11 October 2016, 07:24 »
Sorry yes VW warranty bought used from VW.
Yeah car seems to be running fine.
I first noticed it when the car was idle for a couple of mins all fine then it was like a loud blowing type of noise.
Then sunday seems to be making a noise when im driving even my gf mentioned it, sort of like a grinding noise until i press the gas pedal
I will try take a video after work
edit - taking it to VW saturday for them to listen and a test drive....
« Last Edit: 11 October 2016, 12:31 by Marjon99utd »
Offline Marjon99utd
Re: Engine noise
« Reply #4 on: 11 October 2016, 18:28 »
Sounds like coming from front of the engine...near thw throttle (i think)
https://youtu.be/VU2d1SizNRk
Its like a rumble/vibration noise..you can hear it from 4 seconds to 10 on the video pretty loud
Offline Marjon99utd
Re: Engine noise
« Reply #5 on: 13 October 2016, 20:50 »
Another video of a different noise coming from the passenger side
https://youtu.be/PXFYuLyRgo8
Any help?
« Last Edit: 13 October 2016, 20:55 by Marjon99utd »
Offline SunnyGTI
Re: Engine noise
« Reply #6 on: 13 October 2016, 21:38 »
The first video just sounds normal to me but what's the whirring noise in the second video?? Sounds like something is moving or adjusting but I'm not sure what it could be
TBH I'm gonna listen to see if my car does this lol
Offline Marjon99utd
Re: Engine noise
« Reply #7 on: 13 October 2016, 21:40 »
2nd video noise is coming from fuse box i think
Offline Snoopy
  • Moderator
  • Geoff.
Re: Engine noise
« Reply #8 on: 15 October 2016, 17:44 »
In the second video is that mechanical veep noise you zooming in and out.
It could be the electronic flaps on the intake manifold if not.
That rattle to me in the first video sounds like a heatshield rattle.
The metal clips that hold them on do rot and can fall off causing a rattle. Have a look under the car behind the engine.
Current Garage:
35+ years of GTI ownership.
Offline Marjon99utd
Re: Engine noise
« Reply #9 on: 15 October 2016, 19:25 »
No the noise is the car in the 2nd video and is coming from around the fuse box area
1st video noise seems to be coming from pulley? I will check though
Its going into vw in 2 weeks anyway
Thanks
« Last Edit: 15 October 2016, 19:26 by Marjon99utd »
