Author Topic: Engine Fault Workshop!  (Read 2952 times)
Offline seabrook132
« on: 03 October 2016, 21:26 »
So was driving to work this morning at just before 6am. About a mile away from work (30 mins and 20 miles from home) and the car splutters and the EPC light illuminates and 'Engine Fault Workshop!' is shown in the DIS. This then goes away and car runs fine for a second or so and then lights come back and engine is now running rough. Drives like this for a bit and then runs a bit smoother but with reduced power until I pull into work and turn off.
Busy day so did't get a chance to come out and look at the car at all until time to leave. Have a check around under the bonnet.  Notice some oil around the camshaft position sensor but nothing else obviously wrong so chance a start. Engine runs fine. I have VCDS at home so I think at this point that I'll see what happens, drive gently and hope to get back home where I can give it a scan. Engine runs fine all the way back.
Back at home and this is what comes up on the scan:
Monday,03,October,2016,13:58:16:19790
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 16.8.2.3
Data version: 20160926 DS261.0
www.Ross-Tech.com
VIN: WVW**************   License Plate: *******
Mileage: 136840km-85028mi   Repair Order: 20161003-1
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 14 15 16 17 19 25 2E 37 42 44 46 52 56 62 72
VIN: WVW**************   Mileage: 136840km-85028miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0050
   Revision: AAH18---    Serial number:
   Coding: 0403000C1C070060
   Shop #: WSC 01357 011 00200
   VCID: 67DDEBF556209A7A15-8032
2 Faults Found:
000017 - Bank 1: Camshaft A (Intake)
               P0011 - 000 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 136812 km
                    Time Indication: 0
                    Date: 2011.02.24
                    Time: 05:45:45
             Freeze Frame:
                    RPM: 1850 /min
                    Load: 51.0 %
                    Speed: 75.0 km/h
                    Temperature: 95.0∞C
                    Temperature: 7.0∞C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.970 V
000833 - Camshaft Position Sensor (G40)
               P0341 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 14
                    Reset counter: 255
                    Mileage: 136813 km
                    Time Indication: 0
                    Date: 2011.02.24
                    Time: 05:46:45
             Freeze Frame:
                    RPM: 1569 /min
                    Load: 41.9 %
                    Speed: 53.0 km/h
                    Temperature: 94.0∞C
                    Temperature: 9.0∞C
                    Voltage: 13.970 V
Readiness: 0000 0000
I've taken out the camshaft position sensor and given it, the connection to it and the area around a clean up. Thinking that maybe the leak past the o-ring of the sensor has got into the electrical connection maybe? New sensor and associated o-ring on order as it's only a cheap part and needs replacing due to the leak anyway.
Anyone seen this problem or fault codes before? Not convinced that the sensor is the issue even though car is running fine at present. Always a worry to see timing faults particularly with all the history of tensioners failing etc even though mine is 2011 car. Could this be pointing to something far more serious?
Current plan is to fit the new sensor when it's here and monitor after that. Possibly get the car booked in at a local specialist to get the timing checked?
2011 GTI DSG 5dr, Tornado Red, 18" Monza Shadows, Heated Leather, RNS-510, MDI, Bilstein B16 PSS10 Coilovers, Ohlins DCC Cancellation Kit, Audi TT-RS Front Top Mounts, Whiteline 24mm Rear ARB, Michelin Pilot Sport 4, 034 Motorsports Street Density Engine and Gearbox Mounts, Audi R8 Red Coil Packs, NGK BKR7EIX, Millers 5W-40 Nanodrive
Offline Snoopy
  • Moderator
  • Geoff.
Current Garage:
35+ years of GTI ownership.
Offline seabrook132
Re: Engine Fault Workshop!
« Reply #2 on: 04 October 2016, 20:42 »
http://wiki.ross-tech.com/wiki/index.php/16395/P0011/000017
Thanks for the link Snoopy. I'm gonna have a look and see if there's a way of checking the N205 valve with VCDS, as I believe it needs a special tool to be removed for visual inspection/replacement? I'll have a check of the relay when I get the camshaft position sensor in to replace too.
Car was driven carefully to and from work today without issue, hoping it's just a sensor issue. In any case I'm on sensory overdrive while out in it trying to listen for abnormal noises etc so will try and get a it booked in for a timing check at a specialist soon. May bring forward my planned replacement of the chain tensioner and chain to be safe too.
