Author Topic: 16 Valve fuel pump noisy HELP  (Read 3169 times)
Offline Suzukimadkev
« on: 03 October 2016, 14:20 »
Hi all  hope someone can help on this, I Broke down this morning ,RAC man came said it sounded like fuel pressure ,anyway got car home and had a look and managed to start it  but fuel pump is noisy and the engine sound goes up and down in unison with the pump ,I'm guessing it's the pump or could the relay cause the same problem . If it is fuel pump then which one ?
  https://www.youtube.com/watch?v=c7n6PFuRuV8&feature=youtu.be
« Last Edit: 03 October 2016, 14:35 by Suzukimadkev »
Offline lemski
  • 16v
Re: 16 Valve fuel pump noisy HELP
« Reply #1 on: 03 October 2016, 18:34 »
Itll be underfloor pump being noisey. If intank pumps gone itll cause lack of flow. Best way to check is pull of the feed from the tank and see if it comes with a good flow.
« Reply #2 on: 03 October 2016, 19:23 »
Thanks for your help I've ordered new pumps and filter anyway I'll post the outcome when its done
Offline lemski
  • 16v
« Reply #3 on: 03 October 2016, 19:55 »
Be carfull with the housing on the pump. Rediculas to find a second hand one these days and silly money when you do
« Reply #4 on: 05 October 2016, 17:39 »
Update on today's progress.Turns out some plonka in the past has cable tied the pump housing /bracket leaving it very loose, so ordered correct mounts . I had a game taking the fuel pipe off the pump though lol and  The accumulator is very rusty , should I change it or will it be ok inside ?
Offline lemski
  • 16v
« Reply #5 on: 05 October 2016, 17:50 »
If you can get one at a reasonavle price change it. Bit you may find youll be changing the pipes aswell as sometimes the banjos dont play ball
« Reply #6 on: 05 October 2016, 18:13 »
The banjos were a pain lol but all off now I poured hot water on them and they came off .........eventually . Accumulators are pricey lol I'll have to send the her indoors out to work  :laugh:
Offline lemski
  • 16v
« Reply #7 on: 07 October 2016, 07:58 »
I know. The kjet fuel set up is expensive
« Reply #8 on: 11 October 2016, 19:02 »
Car  sorted now , thanks for the help much appreciated  . I bought a new accumulator, pipes and fuel pump that seams to sorted the problem ,car runs loads better now .
