Author Topic: Advice on brakes please  (Read 2596 times)
Offline FBASH1R
« on: 03 October 2016, 12:38 »
i have brembo pads and pagid discs..bout a month or two new..i get brake fade and bit of smoke when i went on a spirited drive (im stage 2) ...would doing a fluid flush to dot 5.1 fluid and doing hel lines help? or should i just go to vw and get a fluid flush with the dot 4? Thanks
Offline lemski
  • 16v
Re: Advice on brakes please
« Reply #1 on: 03 October 2016, 19:57 »
5.1 takes abit more heat so would help. The hel lines will give you better pedal feel as they wont 'move' as much.
Offline Rowley102
« Reply #2 on: 25 January 2017, 14:18 »
5.1 fluid, braided lines will help with boiling temp and the feel of the brakes. But the best thing will be to get some good pads, i use ferrodo DS2500 and there awsome. There expensive but there unbelievably sharp and dont fade at all
