Author Topic: Rear bumper irons/towbar removal  (Read 7108 times)
Offline Mattyj
« on: 02 October 2016, 16:17 »
Having trouble getting the tow bar off it attaches like the bumper irons but theres no nut inside the window where the bumper iron fits is like a threaded washer thats not welded to the iron so spins if bolts real tight got the front two out using mole grips but cant get them in for the backs any ideas??
Offline lemski
  • 16v
Re: Rear bumper irons/towbar removal
« Reply #1 on: 02 October 2016, 18:29 »
Goes through the same.holes as the bumper iron? Where the 2 bolts either side are. Should be welded nuts on the iron. If the nuts have broken the welds then all I can think of is undo the 13s that hold the legs to the iro and then try get a spanner in there with the bumper out the way. Failing that drill the back bolts and have new nuta welded onto the iron after and replace the bolts.
Offline Mattyj
« Reply #2 on: 02 October 2016, 20:36 »
Dude you the inly one that answers 😂 Theres no nut on the bk so a soanner would be useless its a towbar beam so not orginal irons, its a rubbish design
Offline lemski
  • 16v
« Reply #3 on: 02 October 2016, 21:03 »
Hmm I think drilling is the only option. Csn you get q pucture up. Might he able to see it more as all I can think is an original  iron with a tow bar, bar bolted under it using the same bolts
Offline Mattyj
« Reply #4 on: 02 October 2016, 21:23 »
Will do mate be end of week now though
Offline lemski
  • 16v
« Reply #5 on: 03 October 2016, 08:03 »
Thats fine, ill be here.  :laugh:
Offline Mattyj
« Reply #6 on: 09 October 2016, 19:17 »
Offline lemski
  • 16v
« Reply #7 on: 09 October 2016, 21:37 »
That one in the distance. Got a welder? Weld the nut on and undo. As long as you can get it to stick its worth a shot.
Thats what id be doing or finding so gips that are long nosed to hold it.
Offline oakgreener
« Reply #8 on: 09 October 2016, 21:59 »
Can you get a pair of mole grips onto the nut?
Offline Mattyj
« Reply #9 on: 09 October 2016, 22:19 »
Its not a nut,it has no flat edges its round, not tried welder,long nose grups no and mole grips no its a pain right!?
