Author Topic: GTI PP coolant overheat  (Read 6310 times)
Offline uzinusa
« on: 30 September 2016, 12:24 »
Thought I'd just advise you of what happened to my GTI.  It's nearly 3 years old with 30k on the clock and has been utterly fault-free throughout.  However, the other evening I was just driving easily around town and the temp gauge went through the roof; the car entered limp mode capped to 4k rpm and engine and epc warning lights came on.  The following day I took it to the dealer (it's still under warranty) and they couldn't look at it but the fault codes had cleared and temps were normal so I drove the short journey home.  Temp went up again and fault ligths appeared so I suspected thermostat or waterpump fault.
To cut to the chase, took it in today and as suspected there's a waterpump failure, to be replaced under warranty.  They're taking photos of the pump for me but VW Germany want the failed part back.  However, it's a black plastic impeller that has detached from the metal drive shaft and hence wouldn't rotate properly.  Iv'e asked what is different about the new part (to be fitted Monday) and await a reply, however I was clearly concerned that I'd receive an identical part with a design fault (imho).
Any thoughts on how I can go about obtaining as good a service and future proofing as possible really welcome. Thanks.
« Last Edit: 30 September 2016, 12:30 by uzinusa »
GTI PP 3 door, DSG, Carbon Grey Metalic, DCC, Keyless, Discover Pro
Offline mcmaddy
Re: GTI PP coolant overheat
« Reply #1 on: 30 September 2016, 13:49 »
I thought vw had stopped using plastic impellers?
Offline uzinusa
« Reply #2 on: 30 September 2016, 14:00 »
I'd have thought so...we'll see what the photos show although ideally I'd like to get my hands on it to better see the failure.
Offline Sootchucker
« Reply #3 on: 30 September 2016, 16:25 »
As Mcmaddy, said, thought this would have now been old news ? I remember this happening back with the MK5 Golf's (and indeed my 2005 MK5 GT TDI), that snapped it's impeller (under warranty) which was subsequently replaced with the "new" metal impeller version.
Guess that's as a result of cost cutting again ?
Offline Rhyso
« Reply #4 on: 30 September 2016, 16:47 »
MK4's were famous for it
They were plastic, then became metal, then became plastic during the lifecycle of the MK4
Offline monkeyhanger
« Reply #5 on: 30 September 2016, 19:22 »
It's not cost cutting, it's "weight saving".  :whistle:  :grin:
Offline lemski
  • 16v
« Reply #6 on: 30 September 2016, 19:52 »
Its always the same. I remeber the amount of 1.8t having the plastic water pumps and when ordering parts asking for metal
Offline GTI_Ant
« Reply #7 on: 30 September 2016, 19:56 »
I'm dismayed to hear the're still using plastic.  I remember this on the MKIV but then you'd be replacing the water pump with each cam belt change.
GTi Clubsport DCC winter pack rear camera
Previous:
7.5R 3dr DSG DPB Prets Dynaudio
MK7 GTI PP Tungsten Silver Manual Nav Dynaudio Winter Pack Park Assist
Offline barrym381
« Reply #8 on: 30 September 2016, 19:56 »
Don't fancy having a metal pump fitted to my car  :smiley: if a plastic one fails they just spin on the shaft a metal one tosses the belt
Offline GTI_Ant
« Reply #9 on: 30 September 2016, 20:09 »
No belt on his motor it's driven from one of the balancer shafts by a chain i think.
Previous:
