Poll
What do you have your auto lights set to?
Early
3 (17.6%)
Medium
2 (11.8%)
Late
12 (70.6%)
Total Members Voted: 17
Author Topic: What do you have your auto lights set to ?  (Read 8742 times)
Offline Wrex22
« on: 20 September 2016, 18:33 »
Just wondering what everyone else has then set to :rolleyes:
Offline The ANT
Re: What do you have your auto lights set to ?
« Reply #1 on: 20 September 2016, 18:42 »
I only have a mk6 but i have them on constantly, day or night to make my car more visible to other road users.
Suffering from a severe and unforgiving case of GTItis
Offline fredgroves
« Reply #2 on: 20 September 2016, 20:30 »
LED DRL's do quite well when its light, but EARLY for the headlights seems like a sensible option - its not as though they come on any time other than when being a bit more seen is a good idea.
Unless you've stolen it, why wouldn't you want to be seen?
Jackie Treehorn
« Reply #3 on: 20 September 2016, 20:57 »
Does it seem like a dumb question if I've had the car 2 years and don't know what you mean by early/medium/late?
Online Watts
« Reply #4 on: 20 September 2016, 21:03 »
Me too :embarrassed:
Previously:
Offline fredgroves
« Reply #5 on: 20 September 2016, 21:03 »
LOL, basically, how sensitive the daylight sensor is - early will mean it will trigger the headlights with more outside light than normal or late.
Offline monkeyhanger
« Reply #6 on: 20 September 2016, 21:05 »
I've never had bother seeing a big painted metallic lump on 4 wheels coming towards me from behind, lit or unlit.
Upon seeing headlights, you used to know that you had either a Volvo or a Motorbike behind you at one time, and be prepared for the motorbike to do something daft like aggressively undertake or squeeze through an impossibly thin gap between you and the car next to you in the other lane, but now everyone has DRLs, I don't think motorbikes stand out as motobikes when the headlight first catches your glance.
I don't think they make cars any easier to see in broad daylight than they were already were.
Offline fredgroves
« Reply #7 on: 20 September 2016, 21:16 »
The experts seem to disagree:
http://www.swov.eu/rapport/R-97-36.PDF
Which is why we all have DRL's now.
« Reply #8 on: 20 September 2016, 22:20 »
A ton of hypothesis, theories and assumptions in that report - pretty light on actual facts. One example of the  inconclusive stats it uses shows adverse DRL effect on visibility/instant recognisability for motorcycles,causing more motorcycle related accidents upon the introduction of DRLs in Denmark, but dismisses a 16% rise in these accidents as insignificant, yet excludes them from the data they use to try to demonstrate a reduction in accidents with DRL introduction. There are a lot of shaped and cherry picked stats in there to try and prove the point. Lots of waffle in there to try and mask preferential use of data that supports their hypotheses and exclusion of that data which does not. Some parts of that report sound like they came straight from the mouth of a political spin doctor.
It would be difficult to put a number on the effect of DRL in reducing accidents when so many other factors come into play - better brakes on newer cars, tech like ACC and lane assistance, speed cameras everywhere making people more aware of their speed and the fact that many cars on the UK roads don't have DRLs are just a few. On a poorly lit day you should certainly have your lights on, but on a sunny day? Definitely not convinced.
How much awareness of the car behind prevents accidents? It's awareness of the car in front or alongside you that prevents most accidents (and you can't see the DRLs on the front of the car from there), as the car in front can do very little about the car behind running into them.
Most accidents happen as a result of sideswipes at roundabouts, people coming in or out a lane right into a car already in the space they wish to occupy or via a shunt from behind when the car in front has braked - DRLs on the front of the car aren't going to prevent someone driving in the back of you or make it any less likely, changing lanes straight into the side of someone isn't going to be prevented by DRLs either. If the person colliding can't see the other car's DRLs prior to collision then they aren't going to help.
I'm sure the fuel companies would encourage it to reap the rewards of increased fuel usage (albeit 0.9% according to the report you linked to, not huge on an idividual basis, but noticeable collectively), one of the bones of contention for some of the EU member states that opposed the introduction of DRLs.
« Last Edit: 20 September 2016, 22:34 by monkeyhanger »
Offline fredgroves
« Reply #9 on: 20 September 2016, 22:58 »
The UK government sort of agreed with you when they reviewed that paper.
I couldn't find the whole document online, but the review is discussed here together with a brief version of their conclusion:
http://www.dft.gov.uk/rmd/project.asp?intProjectID=10315
Basically whilst they doubted the original report due to its methods, another 23 similar ones (with different methods) have been looked at and the conclusions are broadly the same, therefore its probably correct.
Maybe that's the infinite monkey effect :D
