Author Topic: Mk2 Golf gti 16v keeps cutting out  (Read 3408 times)
Offline jimbolondon
« on: 18 September 2016, 14:28 »
Hi all! I'm new to this, so be gentle!
I have a 1990 mk2 16v which has a cutting out fault I can't get to the bottom of.
It will start up fine and run great. I'll take it out and quite often return no problem (with a big smile on my face!) But other times, usually after it's warmed up it will just completely cut out. The rev counter drops to zero and the ignition lights stay on. The car will not re start.  It turns over but does not fire. After some amount of time (30-60 mins) it will fire and run as if nothing happened. Quite often I can get it home, but it will usually cut out again. I have replaced the following: Plugs, leads, rotor arm, dizzy cap, ignition module.
Your thoughts and any advice would be greatly appreciated as I'm at my wits end!! Cheers
Offline lemski
  • 16v
Re: Mk2 Golf gti 16v keeps cutting out
« Reply #1 on: 18 September 2016, 15:35 »
Fuel pump relay?
Is there any pattern to it cutting out at all
Offline Brighouse-gti
« Reply #2 on: 20 September 2016, 17:51 »
I had a similar issue with my 8v, turned out to be a dodgy wire that ran from the connector in the back of the boot to the underside fuel pump. Replaced the small section of loom and it's been right as ever since.
Offline h8v
« Reply #3 on: 21 September 2016, 07:48 »
Rev counter immediately dropping to zero indicates a lack of sparks.
Cutting out when warmed up, then working again when cooler points to a heat related problem.
I'd suggest the hall sender on the distributor.
To check if it's a fuel-related fault, carry some Easy Start with you and next time it happens try injecting some into the air intake to see if it will run on that.
Offline ewane_l
  • MK2 16v
« Reply #4 on: 08 October 2016, 06:49 »
i'm having same issue   :sad: did you get it sorted ?
Offline Pistol p
« Reply #5 on: 09 October 2016, 08:02 »
Bosch distributor? If so they have a habit of intermittent faults.
