Author Topic: climatronic Help!  (Read 1949 times)
Offline PaulMK4GTI
climatronic Help!
« on: 30 September 2005, 09:38 »
Morning guys, my climatronic's not been blowing cold enough so i took it to get re-gassed yesterday but, as things are never simple, it turns out the climatronic has an electrical fault and the compressor isn't getting a live feed. The fuse is fine and the guy got it working by giving the compressor a direct feed from the battery. The rest of the climatronic system is working fine but it's just not turning on the compressor. Any ideas?
Cheers in advance.
Paul.
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: climatronic Help!
« Reply #1 on: 30 September 2005, 18:10 »
Surely running a new live feed should not be too difficult ,if you cant do it yourself I'm sure that an auto electritian would sort it out cheaply. :undecided:
Even tho the fuse may look ok, have you actually tried changing it, you never know and this will be your cheapest fix by far :wink:
Offline PaulMK4GTI
« Reply #2 on: 03 October 2005, 10:14 »
The problem was actually the engine coolant temperature sensor. According to the AC guy it's quite common, getting it replaced tonight. Cheers anyway.
Offline djshort_stuff
« Reply #3 on: 07 July 2010, 09:23 »
hello just a quick question where abouts is the engine coolant temp sensor, i take it you dont mean the thermostat? Thanks
« Reply #4 on: 07 July 2010, 09:43 »
 I might be wrong but how would that affect the air con.
Offline Rhyso
« Reply #5 on: 07 July 2010, 09:47 »
http://www.golfgtiforum.co.uk/index.php?topic=88088.0
Look at the date.........
« Reply #6 on: 07 July 2010, 09:48 »
Yep ok, but would it affect the air con.
Offline Rhyso
« Reply #7 on: 07 July 2010, 09:50 »
nope
« Reply #8 on: 07 July 2010, 09:52 »
nope
Thank you :afro:
